Enables the generation of the OSPF router alert IP option.
This command has no keywords or arguments.
Disabled.
Not applicable.
The following command enables the OSPF router alert IP option:
enable ospf use-ip-router-alert
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
